Non-working 9005 HID conversion.
Help!
2005 xk8
I pulled out my LED Hi Beams, as they didn’t have any depth of light and installed a set of HID 9005s with high hopes.
I had been so pleased with my earlier installation of HID 9001 low beams that I was hoping for an improvement over the stock bulbs. Well, I’m baffled…neither hi beam functions, they both have +12v going to the ballasts. The odds of both units being faulty I would image is pretty rare but I do not see where I have gone wrong.
The only question I keep having is that there was an 8” length of cable with a male and female connector on each end which was plugged into the ballasts. I removed them as they were inline connections without any ICs and I thought of them as simple input extensions, maybe I was wrong. Since I mounted everything inside the light housings I didn’t have a lot of extra room for these extensions and I don’t really want to pull it all apart again unless it is necessary for replacement of a component.
Any thoughts as to what I might have done wrong?
To recap:
Fuses good
Power measured at input to ballasts
None functioning lights (both)
wj
2005 xk8
To recap:
Fuses good
wj
I would double check that the positive and negative are the right way round to the ballast - it won't work otherwise.
DavidYau (01-21-2020)
Here you go. Read 5A and you will, or rather should, see the solution. https://www.jaguarforum.com/showthre...=1#post1025402
Dont forget to let us know if it works wont you??
Thanks!
Thanks!
Thanks!
Thanks!
FranckC you were on the money. I reversed the plugs and everything works.
For those that wonder how someone can ‘plug it in backwards’;
the ballast has a female receptacle with a locking tang, the jaguar plug has the counterpart on its plug…so I thought the normal approach would suffice, it didn’t. I assume that when these are manufactured this small point isn’t of much concern. Never the less, they now function.
I’ll report back next week after I get a chance to try them out at night and make some adjustments. I can tell from the pattern on my wall they are a major improvement compared to both the original bulbs and the LED conversion I did earlier.
I guess the LEDs will finally reside in my fog light assemblies.
wj
Great stuff. I can imagine how it felt when they did light up.
People have asked me why did I not install LED lights and it was because of reports from people like yourself.
The HID lights make a massive difference. Its one mod I highly recommend.
Thanks for letting me know it worked. I do a lot of writing about our XK100 cars and its always good to get feedback. Thanks again for letting me know it worked!
