noob with some chain tensioner, water pump, and engine questions...
Guest
Posts: n/a
hello all. this is my first post since joining the forum. i've recently sold a couple corvettes, and i'm looking for something new and exciting. i've always loved jaguars, especially the xk8 series in coupe form. i've been lurking around here reading some of the threads and posts on chain tensioners, water pumps, and some sort of cylinder coating, so having said that, can some give me a rundown on tensioner/water pump/cylinder wall issues with respect to specific years. it seems that since 97 model year, there has been technical improvements, but i'd like to avoid any issues out of the shoot. presently, i'm thinking a 2003/2004 model year with something less than 50K miles on the clock. finally, should i be aware of anything that might be considered a problem areas up thru 2004. if jaguars are anything like corvettes, i know they can be money pits unless one is willing to do most of the maintenance themselves. BTW, i'm an old aircraft mechanic and retired engineer, and pretty fair with the wrench, so i'm not opposed to getting my hands dirty.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Welome!![Icon Band](https://www.jaguarforums.com/forum/images/smilies/icon_band.gif)
Your choice of model years is good as most of the mentioned issues were resolved by then. If you want an older car as a hobby because you like to work on them, then go for it. Otherwise, newer is better all things considered. Read alot of posts and FAQs and get a feel for what you're looking at. That said, I enjoy my older car and it's about as reliable as most of my others so far. Just do the required upgrades before big trouble hits.
Mike
Mike
Welcome to the forum!
. . . and, hopefully, to the wonderful world of Jaguar. I think you will find a number of Corvette owners here that have or previously had, Corvettes.
If you are looking at an '03 up model you are going to miss all the fun. With the introduction of the 4.2L engine and 6 speed transmission in '03 all the 6 years of field engineering was successfully brought to a conclusion.
To more completely answer your question;
With the '99 model year the AJ26 engine was replaced with the AJ27. For the most part that solved the water pump, loss of compression, and throttle body issues. That left the Nikasil cylinder lining, transmission and tensioners to be addressed in '00, 02 and '03. The other 30 or 40 common problems were also fixed along the line.
So buy a '03 up car and enjoy. Weak front suspensions components and the convertible top hydraulic system were just never fixed.
