Nut on Shock Shaft
2005 XK8. I noticed that the nut at the top of the right shock (viewed from the open hood ) has moved from the center to one side. A normal indication when shock mount is worn, but these shock mounts are relatively new and shows no sign of deterioration.
Is this a common occurrence, or is it possible the nut is not tight enough? If loose, is there a tool, short of using a pair of vise grips, that holds the shaft while the nut is being turned?
Chuck
Chuck
What new shock mounts did you install? There have been reports of early breakdown of some of them, particularly those purchased from partsgeek.com....
I recommend the poly shock mount kits from Welsh Enterprises. They have certainly held up well on my wife's 2006 XK8 the past couple of years....
Chuck Schexnayder (12-20-2017)
The following 2 users liked this post by cjd777:
Chuck Schexnayder (12-20-2017),
Jon89 (12-21-2017)
cjd777, Thanks, and have tried to order them from Welsh, but there must be a bug in their web site. Ive ordered from them before with no problem, but this time it's a no go.
I sent them a note and based on a no answer or whatever, will call.
Jon 89, Don't remember who from, but they were listed as like OEM.''that's a lesson learned on my part". Never to old to learn they say and I'm living proof. I'm trying to order the ones you recommend from Welsh and will when I get through to them....
Thanks to you all.
Chuck
Thanks to you all.
Chuck
Regardless of who I order parts from, I always do so over the phone. You get the chance to discuss the vendor's experience and opinion of the particular component you are interested in, you can confirm that you are indeed getting an exact-fit part, and you can ask if they can offer an additional discount or a lower-than-advertised price. It is always worth the slight additional effort required to order by phone rather than by website....
jon89,
Of course your correct and I normally do use the phone, but I was on the net and was checking prices and when I tried to order, it then became a challenge and I just hate to give in to this darn machine or some silly web site.
Since I'll turn 83 in Jan., maybe I should shut this computer thing down for good. ;-))
PS: We use to live in Fayetteville and I loved the area. Why I ever left and moved to Florida, I'll never know. :-(
Thanks Jon
Chuck
Thanks Jon
Chuck
Jon89 (12-22-2017)
penguin
03-18-2013 12:10 PM
H20boy
General Tech Help
10-31-2010 08:27 PM
