O2 Sensor -- P1646 which one is it?
Welcome to the forum. It's the one on the right side viewed from inside the car, passenger side wit LHD.
When ou have time please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Andreas Hübner (07-08-2015)
it is the upstream one up behind the right rear (passenger) of the motor before the first cat over there. Easy repair if you want to do it on your own. Go by a set of O2 sensor removing socket set, mine came in a 3 set and go for it. If your motor is free of rust it will come right out. Mine did , was easy on my drivers side. Little tricky to get the socket on but easy. Be careful when unplugging it from the harness, don't tug on the wires on the plug end. I did and pulled out the brown wire. Got it back in, but time to time it loses contact and I have to go out and jam it back in the rubber grommet in the plug holding it in.
Just replaced the O2 sensor and erased the error code from the system ... however, after driving for about 20 minutes and restarting the car -- the engine light is on again w/same error code. Strange ... I definitely replaced the correct O2 sensor. Don't know what to do anymore.
The possible causes of P1646 are:
1. HO2S heater failure
2. HO2S sensing circuit short circuit to ground or high voltage
3. HO2S sensing circuit open circuit
4. ECM failure
As you have replaced the HO2S, you can eliminate (1) and as the car starts and runs, you can eliminate (4).
Check the connector and harness.
