O2 Sensor Replacement
Good Afternoon:
After doing some digging around, I have found that the wiring to the front O2 sensor on the passenger side of my XKR has been chewed up by some rodent![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
I have decided to give replacing it a go.
I have two questions:
1) How do you remove the protective silver covered plate that is protecting the 02 sensor? Is there anything else I should be be weary of before replacing?
2) Which Side is Bank A on the US Models.?
Thank you.
Thank you.
The A bank is passenger side on a 2001.
Are you talking about the stiff fiberglass-like material heatshields? They are just bolted on.
Access to the O2 sensors is very limited on the XKR, and they often require a huge amount of torque to remove. You may find it easier to remove the entire catalytic converter to get the sensors off.
Attached is my write-up on a catalytic converter upgrade, which will have useful information for this job.
johnpreston84 (11-14-2012)
KarimPA
09-03-2015 07:32 PM
innzane
09-02-2015 10:08 AM
