OBD codes
Well, it looks like the project for the morrow is to clean the wheel speed sensors, as I'm getting "ABS/ASC not available" messages. My OBD reader is showing a P1111 code, but I'm not sure what that refers to. I looked at Gus' file in FAQ's, but I couldn't find any OBD code explanations, although I'm sure I've seen them somewhere? Too much top-down driving lately has fuzzied the brain maybe....
The P1111 means that your system check is complete. You can find this info under OBD codes roe the year car you have. For example this is for a AJ27 Engine Management 1999 MY http://www.gusglikas.com/images/Auto...J27%201999.pdf Look on the first page at the bottom
You will always have either P1000 or P1111. Neither indicate a problem. When the codes are reset the car goes through a cycle to make sure all of the emissions bits are working properly. It takes several drive cycles to complete. So, after you reset your codes, it might take a day or two, or even a week or more before the Drive Cycle Status is complete. Once it is complete, you'll get the P1111. Here in North Carolina the Drive Cycle Status has to be complete before you can pass an emissions inspection. That prevents someone from resetting their check engine light five minutes before they have an emissions inspection done. If you reset your trouble codes you'll get a P1000 until the cycle is complete, then you'll get a P1111.
If you do end up needing a CPU fix, I recommend these guys: Module Masters > Home - fast, honest and good work. In my case I wish I'd gone straight to them at the outset and not futzed around with interim solutions...
Well, it looks like I skated once again! With particular thanks to Gus and the Rev, I cleaned the wheel speed sensors- they were all dirty and scuzzy-looking - and the "NO ABS/ASC" message is gone. May the FSM be praised! In fact, I was SO happy, I went out and bought an X-Type today, just to keep the "8" company in the garage. Now I'll be able to 'Jag it' even in wintertime. Although I think the Jeep will still have to do the heavy slugging.
Thanks again, all. Will update my garage once I get the new Cat home.
Gus (07-13-2011)
Congrat's! If you run out of garage space up there, I'll be glad to make room here for the E-Type (or does that belong to a relative??)
It will be a chore to rearrange things here, but after all what are friends for?
![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
philwarner
25
06-26-2021 05:43 AM
Will P
09-19-2018 08:36 AM
KarimPA
09-27-2015 08:46 AM
Bob Gelston
09-14-2015 11:08 PM
