OBD Gauge pod, a must for any X100
Old 08-18-2022, 09:26 PM
giandanielxk8's Avatar
Received 1,453 Likes on 780 Posts
Originally Posted by Throwback
@giandanielxk8 Thank you for the kind offer! However what I actually need is the bezel, i.e the walnut veneer trim panel around the nav screen. The nav screen itself I will most likely be discarding, although a spare to canibalise the plastic body from might be useful. I notice these sell cheaper than the three dial veneer panel, so i figure more people are converting nav screen-> dials than the other way around. If you have the veneer panel available as well, even if the tabs are broken, I would be very interested.
Sorry no, I don’t have the veneer panel. I have not converted to the three gauges.
Old 08-19-2022, 12:43 AM
Kuddlesworth's Avatar
I would like to do something similar but I would want it to look really OEM.
Old 06-05-2024, 10:35 AM
Paldi's Avatar
"The temp gauge is a "fake" gauge and will not warn you." So how hard would it be to reprogram the gauge, so it doesn't read fake?
Old 06-05-2024, 02:53 PM
Jag#4's Avatar
Forum member has your answer to the temp and oil pressure gauge issue. https://www.thejagwrangler.com/index.html
The following 2 users liked this post by Jag#4:
Dr. D (06-06-2024), zray (06-05-2024)
Old 06-05-2024, 03:17 PM
I can attest that the RealGauge modification works brilliantly and it does have an overheating/low oil pressure alarm.
The following 3 users liked this post by giandanielxk8:
Dr. D (06-06-2024), Jag#4 (06-05-2024), Redjags (06-06-2024)
Richxtype2ds
10-13-2019 02:19 PM
slowcreek54
09-19-2017 11:33 PM
jackra_1
27
02-11-2017 09:08 AM
razorboy
05-09-2015 01:57 AM
weisberg
10-28-2014 09:21 PM
Quick Reply: OBD Gauge pod, a must for any X100
