OBD Gauge pod, a must for any X100
@giandanielxk8 Thank you for the kind offer! However what I actually need is the bezel, i.e the walnut veneer trim panel around the nav screen. The nav screen itself I will most likely be discarding, although a spare to canibalise the plastic body from might be useful. I notice these sell cheaper than the three dial veneer panel, so i figure more people are converting nav screen-> dials than the other way around. If you have the veneer panel available as well, even if the tabs are broken, I would be very interested.
"The temp gauge is a "fake" gauge and will not warn you." So how hard would it be to reprogram the gauge, so it doesn't read fake?
Forum member has your answer to the temp and oil pressure gauge issue. https://www.thejagwrangler.com/index.html
