OBD-II WiFi adapters and ipad or mobile device
It should work fine, but you will be limited to engine & transmission codes and data, as with most generic OBD-II Scanners. There will also not be support for anything that is not sensed in the vehicle, such as oil pressure (there is just a low pressure switch). Some systems allow adding aftermarket sensors however.
Parameters and codes from the XKR
Thanks, I'm just trying to find out now what parameters are measured and if the codes are standard so I can find a wifi / Bluetooth OBD adaptor that will work well.
Anyone have any info on this or has actually done it I would really appreciate it.
rgds Esh
rgds Esh
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
