Obd troubleshooting
Obd troubleshooting
My scanner will not communicate on the serial k line. It does read on the the other networks. The wiring diagrams show ecu, accm, Ktm, and damper control. I do not have a Ktm or damper control. I read -11.53 v on pin 7 to ground. If I disconnect ecu I get -10.02v. With accm disconnected -11.31v. I disconnected batt. Pin 7 to gnd 39 ohms. Accm disconnected ecu to gnd 50 ohms. Ecu disconnected accm to gnd reads 193 ohms. Since ecu and accm are in parallel the resistance checks out. I tested the cable and no ground faults. I looked at both ecu and accm modules did not see any issues with traces or caps. Any ideas on why I am not getting comes?
Jaguars are fussy about scantools as you'll see from this thread in General Tech Help:
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
I think you have the wrong idea of the correct voltage. Typical for ISO9141 is about 10.7V I think you'll find. It is a task of the testing device to pull the pin up to batt+ via 510 ohm resistor as I recall.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
