OBD2 port bad?
OBD2 port bad?
So my cheapie reader connects, seemingly with no issue, but I just tried connecting my icarsoft scanner for the first time and in the diagnose OBD2 mode it reads "fail" for all the checklist. (pic attached hopefully). Also when I "rock" the connector the power to the icarsoft goes on and off suggesting an intermittent connection.
Is it easy to get this port out/replaced? Could I do it fairly easily? Is there some kind of connector attached to the back of the port that could be faulty?
Many thanks
Alan
Many thanks
Alan
I noticed a lot of folks stopped by but no one ponied up. I am not positive but I do not believe there is a connector that can be unplugged for replacing the OBD port. You would probably have to cut and splice. From your description of the fault it doesn't appear that the connector is the problem but the pins on the ICarsoft are the problem. Especially if you can connect seamlessly with the cheap one and have to rock the ICarsoft one.
You might try using electronic cleaner and clean and clean up all of the contacts for the scanner and port.
You can check the electrical manual on jagrepair.com for all the details on the networks page. These connectors are standard (J1962) and can be cheaply bought/replaced individually. Check eBay for all kinds of variants (extensions, breakouts, etc.). There is a fuse, too, but yours seems fine. FWIW, standard OBDII is only available over ISO-9141. There is CAN and SCP, too that should have the Jaguar proprietary codes. That reader should be able to get them if it is Jaguar/LR specific. The ignition is on, right? Engine can be off, but the computers have to be powered on.
Separately, it might be worth checking if there is a software update from the vendor...
alanroberts50 (09-06-2018)
Raising hand...My car has a replacement connector that was installed before I bought it....I don't recall whether or not it worked when I bought the car, but the wire splices connecting the OBD II connector and the car's wires are very fragile and I kicked them apart a few times before wrapping them in an ugly ball of electrical tape (which is fairly well hidden).
Aesthetics aside, it's fairly easy to match the 15 (!) tiny wires with the OBD II port. You just need a schematic and a circuit tester or Volt/Ohmmeter. My schematic is for a '97, but I believe the newer electrical guides also provide a page on the subject. If no one else raises their hand, I'll try to attached a copy. Or have a look at Gus's jagrepair.com . I'm sure it's on his site.
If you find an elegant way to splice the wires (any wires !), I'd love to hear about it.
-100%. I finally have a code and cel p1638. Relay perhaps?
I had the same issue on my chevy truck..looked whete the pins are in the obd2 connector of the truck and found 2 of them pushed back.using a magnifying glass (sorry axx old eyes) I took the screws out securing it and was able to push the pins back in from the backside. I have the icarsoft i930 and use it on my str. In obd2 mode it picks up on the 3rd one...the first one in line that says can
danveenstra
02-08-2015 10:35 AM
Cambo
08-10-2014 06:19 PM
