OBDii Code Results - Can you tell me what they mean?
Please forgive me if I'm in the wrong area, but I'm pretty new here and still learning my way around.
I just got the OBDii scanner codes (Thanks for Reverend Sam's recommendation).
The codes are OEM P0171 and P1000.
Keep in mind that about a month ago, I had the fuel injectors cleaned, and I did put an additive in the full gas tank because I don't drive the car much, and the dealer said to use Bg products Supercharge II inj. cleaner fuel stabilizer on each fill up of gas as this would prevent a build up on the injectors. Not sure if that has created this current problem.
Please let me know what you think. Thanks
philwarner
25
06-26-2021 05:43 AM
scooternva
19
10-27-2015 02:14 PM
