Odd Beep/97 xk8
I recall another post when the car had an intermittent no start https://www.jaguarforums.com/forum/s...ad.php?t=28185 Although the post is about not starting it also had information on the Neutral switch and I think you have an adjustment problem with that switch. I know nothing about the switch other than it is there. I would consider checking it.
it did it again today, driving along, about 3 min into drive. not hitting brakes, not turning on blinker, heat on, drivers heated seat on, radio on, got the three tones again. It is three light/faint tones from where the blinkers make their sound or from somewhere in that geberal region. It IS NOT the same sound as when you pull on gear shifter when car is in park with keys out and you gt that beeping sound that keeps beeping until you let off shifter. This is 3 tones in quick succession. Almost sounds like a bird chirping. Soft fluttering sound amost. Only thing that is of note is that I am real low on gas, in the red, don't know if that was the case the other times though. It has only done this once while driving when it has happened. Never 2x on a trip of any length. Now it seems to do it when stopping or just moving along. again all gauges are reading fine, not warning from display system. Really odd.
The only times I know of a tone is when;
The shifter is in gear and the key is removed
Seat belt warning
Roof operation full open and full closed
Key left in the car
Emergency brake is on when moving the car
Blinker clicking
Locking and un-locking the car
Door ajar
Add to my list if I missed anything.
You mentioned 3 min into the driveway. Is it rough or flat surface?
Seat belt warning
Key left in the car
Blinker clicking
Door ajar
Pristine97XK8Convertible
04-28-2017 11:08 AM
