Oil cooled Radiator on XKR
Best of luck, keep us posted.
Ghostrider (04-12-2017)
Ghostrider (04-14-2017)
Burnham has the right idea......Don't get close to Kerb's, whatever that is! Here in Texas we don't have Kerb's, Ghostrider.....We have curbs and if you get close to them they will bite the bottom of your Front Bumper and skin all the paint off! We also have what is called, "Speed-Bumps"! Now they will really skin he paint off! Hopefully, you Aussies don't have those yet!
Billy Clyde in Houston
Ghostrider,
The oil cooler on my 03 XK8 was mounted much lower than in Paul's picture and was the lowest/most forward part of the car. Not sure if that's consistent with the XKR but was definitely a problem. After causing one to leak by whacking a parking stop, I moved the cooler up a little by reforming the mounts and forcing myself to pay closer attention (that was the hardest part). The expensive rubber isolater mounts can be found at a lower cost from McMaster-Carr https://www.mcmaster.com/#vibration-...ounts/=176qg5k or perhaps another hardware supplier in your part of the world.
Mike
Mike
Ghostrider (04-19-2017)
