Oil cooler pipes 2001 xkr
To be clear, the _engine_ oil coolers lines are (4) separate sections of "hydraulic" Aluminum/rubber that have a ball park lifespan of 10 years. They are somewhat pricey ($400?) but pretty straightforward to replace. One or more seeping joints is red alert as they ALL see max oil pressure, so all (4) need to be replaced at once. If a joint bursts, all the oil is pumped out of the engine in seconds, and the ignition needs to be shut down FAST.
The _transmission_ oil coolers are a combination of hard metal pipes with flex ends to the cold radiator end tank. Those tend to last but are a bear to replace as they snake around a bit with multiple intermediary hold points. I have no direct experience with that job.
Best of luck, keep us posted.
jagxkrtoofast
05-19-2012 09:22 AM
