Oil dip stick tube removal
Hello all,
I am having difficulty removing the oil dipstick tube in order to replace the o ring. I have to replace a leaking cam cover seal. I can cet it to a point but it seems to get caught and I cannot work it free. Any suggestions would be greatly appreciated.
Thanks again,
Mike
Thanks again,
Mike
The following 2 users liked this post by Gus:
Dr. D (02-17-2019),
oldjaglover (03-17-2022)
before you pull it out feed down through the dipstick a length of straightened bailing wire, reasonably heavy gauge. it will act as a guide for the new seal and dipstick tube when you install it as well as showing you exactly where it goes. this worked for me on another nightmare dipstick installation.
RJ237 (02-18-2019)
Any help is appreciated.
Ken
follow-up
[QUOTE=oldjaglover;2507066]What about where the tube is attached to the back of the PAS pump? I'm doing the pump R&R and cannot even see the little clip that the JTIS says is holding the tube to the back of the pump. It's a long way down there....because the PAS pump is actually pretty far down where it attaches to the engine.
Ken
How did this go? Apparently some are more difficult/cooperative than others.
Patrick
Ken
Patrick
jagosaurus
01-10-2013 12:55 PM
