oil fill question - RESOLVED
Did oil change, put in 5 quarts oil, and dipstick shows full. Car sits slightly downhill. Also did oil filter. I have NNE dipstick. Should I put in the other 1.9 quarts or is it possible there's still oil in sump. I'd let it drain for about 10 minutes. I changed the oil a year ago, but don't recall this discrepancy. VIN# is SAJGX2042XC0386..
Last edited by GGG; 07-23-2013 at 01:46 PM. Reason: Add 'RESOLVED' to thread title
The manual for my MY says it takes 6 qts.
If you drained it all out, then I'd put in whatever your manual says that it holds, then find a flat place to check it, but unless someone changed the oil pan or something (very unlikely) I'd go along with what the manual says.
A little more may be better than not enough, but I also hear the overfilling can cause problems with frothing and so forth. Once again, I'd go along with what the manual says.
Received 6,332 Likes
I always check oil level in my garage which is on the flat. My drive has a slight incline so I've just checked to see what difference this makes to the reading. Amazingly, it's almost one quarter of an inch on the dipstick!
Took you'r suggestions. I added 1 quart and then ran car to operating temperature.Then on level ground I checked the oil level, and it read a quart low. Topped it off, for a total of 6.9 quarts (as/per manuel). All is well again. I thought maybe I needed the newer dipstick but I don't. Thanks for you'r suggestions!!!
Norri (07-23-2013)
