Oil Gallery Plug and RMS
I disconnect all the electrics to the gearbox and undo the 16ish bolts of the bellhousing, undo the transmission mount, and use a jack to drop it down? How high off the ground does the car need to be? Is there any seal on the transmission side that should to be replaced?
giandanielxk8 (07-04-2022)
Salo
10-20-2017 10:17 AM
