Oil pan gasket question
Received 2,650 Likes
There are other brands that have engine sump leaks quite regularly, such as the GM Northstar unit. The AJ-V6 seems more prone to this than the AJ-V8.
Hopefully the area was thoroughly cleaned and inspected for any other possibilities such as the cam cover gasket as mentioned above.
Oil pan gasket...
I own an '03 XK8 w a 4.2L and I too see oil that appears to be coming from the oil pan gasket. I have looked for oil coming from above but nothing. I just received the new gasket and will replace the old one soon so, you may not have the only one leaking. BTW, my wife's '07 hyundai elantra had a leak at the oil pan gasket as well... it was just silicone seal but it had to be replaced.
al_roethlisberger
07-16-2024 04:19 PM
Ismael S
05-08-2016 12:57 AM
jetjack
04-11-2016 02:46 AM
