Oil Pan gasket replace
Hi,
After trying without success to find the answer in the Sticky FAQ I would like to know if there is anything special that I need to know before replacing my sump pan gasket(like torq) etc. in a matter of fact I have 3 leaks.... 1- leak oil pan, 2- leak power steering oil, 3- coolant leak. taking it apart on thursday... wish me luck
Thanks for helping
AJ
Thanks for helping
AJ
[quote=Dan R;299185]
12Nm = 106in lb. I checked it using the software tool Torque Converter available for free at www.boltscience.com
For accuracy, please give the year and model of the car. I'm not sure if the pan gasket for the 4.0 is the same as the 4.2. I know the 4.2 gasket is a small silicone one set in a groove in the pan adapter on the engine. The bolts are torqued to about 9 ft lbs. The groove and the pan should be cleaned with lacquer thinner ( degreased) prior to installation.
