Oil Pan Removal
Oil Pan Removal
I've searched the Forum but haven't been able to find any specific information on oil pan removal for my '99 4.0 engine. Lots of info. on transmission pan removal, but no joy on oil pan removal.
I need to drop my oil pan to fish for the plastic "shoes" from the old style plastic secondary tensioners. I've replaced both using the zip tie method (no trouble at all thanks to information from this forum! Thanks. And, yes both were beginning to split at 77,XXX miles.)
Both tensioners were missing their plastic shoes from the moveable end of each tensioner. They are likely in the oil pan, thus removal is necessary.
Are there any pieces of advice for removal or is it straight forward?
I've got a new oil pan gasket. Do I need anything else besides the usual tools?
It's straightforward and detailed in the PDF DpezXK8 attached in post #2
1. slacken all 18 bolts
2. remove all except the 4 at the corners
3. support the pan with the palm of one hand
4. remove the final 4 bolts
5. lower the pan
When refitting, pay close attention to the tightening sequence and the torque.
5. lower the pan
jimmiejag (04-27-2015)
aholbro1
08-05-2021 05:02 AM
