Oil pressure gauge
Received 2,380 Likes
Dale,
Have you considered this from WhiteXKR?:
XK8 / XKR / XJ RealGauge - TheJagWrangler
You'll get a temp. gauge that works properly too! It's on my list of Stuff To Do...
Mike
Mike
Ditto on the RealGauge product. It is by far the most thoughtfully designed add on that I have ever installed with excellent instructions. It was actually fun to do. The existing gauge does provide an accurate reading with this kit; i checked.
Just do not be surprised that at idle and fully warmed oil you will have a reading of 12.5. This is normal.
To my knowledge the audible alarm will also alert you to a low oil pressure condition and all of your existing warning lights will continue to operate.
Over the years I have heard from several owners who said it has saved their engine, which is very gratifying for me.
The following 6 users liked this post by WhiteXKR:
cjd777 (03-15-2017),
CorStevens (03-15-2017),
Jag#4 (03-15-2017),
Orthodixie (03-17-2017),
test point (03-16-2017),
and 1 others liked this post.
I am more than happy to answer any questions.
CorStevens (03-17-2017)
Othodixie,
Getting the triple guage panel to match your current wood is the hard part! See these threads for my adventure....
https://www.jaguarforums.com/forum/x...n-done-161431/
https://www.jaguarforums.com/forum/x...e-cars-163561/
Here's the link to my solution to fitting an oil pressure gauge in addition to the OEM satnav option
https://www.jaguarforums.com/forum/x...-satnav-83919/
The real Gauge kit looks brilliant. I hate the fake oil pressure gauge but assumed it was something I had to live with, and I never knew the temp gauge was a fudged!
Chapeau to the maker!
So I think I will be doing this mod, the only thing putting me off is the dollar pound exchange rate, and the removing of the dash (I'm more of a a nuts and bolts guy) can anyone let me know how long the install of both kits take, and how fiddle it is thanks???
WhiteXKR (03-20-2017)
The gauge cluster dash wood fascia comes removes fairly readily. I would allow about an hour for RealGauge coolant and 1.5 hours for the oil pressure option. Reserving an afternoon is a safe bet. The instructions are very explicit. It is not hard, but bring your reading glasses if you use them, and get a helper if you have color vision problems (to identify wires).
The coolant version is all done from the drivers seat. The oil pressure option also requires you to get under the car right near the oil filter.
Here is a video that shows wood fascia and speedo cluster removal:
All the instructions can be previewed here: http://www.thejagwrangler.com/realga...tallation.html
