oil pressure gauge adaptor
I planned to check my oil pressure with a oil pressure tester but the gauge does not have an adaptor for the M10 x 1.25 thread used on the oil pressure switch.
Here is how I made one.
I purchased a cheap aftermarket sensor from ebay.
Cut off the end.
Ground the nut end flat.
Punched out the internals.
Lined up a M14 x 1.5 bolt that did fit the thread on my tester.
Then welded it up.
Then ground it down
And ready to go!
Will try it out next weekend.
Cut off the end.
Then welded it up.
Then ground it down
And ready to go!
The following 5 users liked this post by RaceDiagnostics:
EZDriver (03-17-2019),
jamdmyers (02-09-2015),
motorcarman (02-08-2015),
MRomanik (02-09-2015),
plums (02-08-2015)
