Oil Pressure Tap Point?
My thread about the OBD gauge. 5 years on and still working fine:-
https://www.jaguarforums.com/forum/x...-gauge-210411/
You can already get cheap plug and play OBD gauges that show the temperature, volts etc. The problem is getting the oil pressure, which isn't supported on the car as standard, so you have to plumb an oil pressure sender into the existing fitting. For me that just introduces another failure point and I don't really want to be fiddling about with something that is working, but for others the reward outweighs the risk.
Are you sure that is showing you the pressure? There are various PIDs for the oil pressure signal, but they are just on-off, If Jaguar ever did fit an oil pressure sender rather than just a switch, that would be a good upgrade route for everyone else.
