Oil Seeping from These on New Ride
Agreed, but having cut my teeth on my first motorcycle, a british bike,( 1973 750 Triumph Tiger) Bought from the original owner in 74. He lived in a bad area, wanted to buy a house in a better area, for his daughter to start school. Knew the guy he sold his old pristine B S A to, he loved the bike, said nothing but good things about the seller. They worked at the same place, that's how it was found.Seems the brits design little flaws into their products to keep you coming back, for parts if nothing else.Many can be cured by small modifications, others take a bit of a redesign on something, & others just keep on happening as nothing else can really be done but replace things as wear parts.
After replacing the VVT seals, not my leak. Still a drip from what looks to be the plastic trans pan, but above it looks to be dry. Ordered a steel one on the web, bought the seal, filter,8 quart's of Motocraft SP trans fluid, from the Ford dealer, will make sure the trans has enough fluid to drive to get the e check, & drive a bit before winter.Change all fluids, filters, serpentine belt, upper control arms, rubber on upper ball joint is shot from what looks like the car wash to me.As well as anything that i see, want to put it back to a worry, & leak free condition.
Separately, double check the fill procedure with the metal pan. The trans takes in one LESS quart as with the plastic pan, and the fill hole to use is on the metal pan, not on the transmission anymore. In other words, the metal pans I have seen have both the fill and drain holes on the pan itself. The plastic pan has just a drain hole, and the fill hole is on the trans.
This place has great write-ups for these transmissions: www.thectsc.com/tree-faq
#28
#31
Well guys got the front the car up enough to see, looks as if the trans plastic pan has been reused, hopefull that is the source of the leak. Got all but 2 bolts loose with the torx bit's, others vise grips handled & tightened them all more than they were loosened, leak should better, if not stopped . Got the fill plug too loose lost, & an ounce or two, the fluid on the floor looked new, so looks like there's plenty of clean fluid.Have the steel pan, bolts, gasket, & 8 quarts of Mercon S P trans fluid so far, will need at least a couple more,will get the o'ringed sleeve, with the electrical connections, & saw something about 3 rubber type shift boots that get hard. Have to pull valve body to get at them, but that should not be too hard to do. They are right under it, & will only fit one way, is my understanding, if so, it's is well worth a little extra effort if things last longer, & work more like new.
#32
Wouldn't viton seals last longer? When mine arrive, i will take one to the local bearing shop to see if viton seals are available, after installing two of the four i ordered to see if they stop the leaks. If not available in viton, will have a set for the next time, if they do will have two.
Viton would be great.. we use those many areas on Porsche engines, like oil return tubes and pressure sending units, assembled with a Vaseline like paste (curil T) and no leaks.
Another thought would be Yamabond which forms a thin elastic film. This is used to seal motorcycle case halves but does not dry as brittle, and not nasty like silicone sealants.
Keep us posted on the viton if found. In the meantime I'm going to replace with the factory seal coated with curil.
XJR-Guy
09-16-2016 04:24 PM
annamiata
09-13-2016 05:36 PM
rhscare
09-13-2016 10:02 AM
