Ok! How many people just live with a coolant smell??
I've done everything I can find (and been suggested by all you great guys on the forum) to fix a coolant smell. Changed almost every hose, coupling, expansion tank, cap, thermostat and housing, plastic manifold, everything basically. Checked for a head gasket issue, you name it. Pressure test found nothing but EVERY time I drive it, there's that smell. Usually in the rear of engine area. All new clamps, ugh!!!
At this point my mechanic has no more ideas. He says just drive it and if it gets worse or I see drops, we'll start again!!
So my question really is: who else just lives with a coolant smell?!?!?!?!
Hi Philhef,
With all the work you have carried out could it be coolant residue somewhere on the engine that is burning off.
If there are no leaks inside or outside, the levels and pressure test is ok and there is no possibility of the smell being something else, then I would agree with your guy and see what happens.
I noticed it on the test drive before I bought my 01 XK8.
It was brief after warm up, and went away quickly. Ten minutes later I smelled it again, just as briefly....no steam or smoke either time.
I chalked it up to having recently been in the shop by the dealer. Maybe residual dampness, grimey finger prints, etc.
The intermittency had me thinking that perhaps small drips were falling on the hot exhaust manifolds perhaps, but like I said, never any steam.
Then I read on this forum about the reservoir tank deficiency...haven't looked into that farther because the smell has diminished a lot since I've been driving her regularly. I believe the repeated heat cycles have evaporated any grime or spillage from the service work, as I hoped.
Still need to inspect the reservoir closely to be sure....Coolant level hasn't gone down any discernable amount that I can tell.
Never a puddle or drip under the car after shut off and parked overnight or longer, no steam from the tail pipes and no visible wetness under the hood...
There are two heater hoses that lead from the thermostat area and head towards the rear, UNDER the intake manifold to the rear of the engine. Significant leaks anywhere around the thermostat or these hose connections...or perhaps in other areas near the rear, can lead to the collection of coolant on the top of the engine block, under the intake manifold where you can't see it. Every time the engine gets hot, it could be burning off this coolant or its residue...but again, you wouldn't be able to see it without removing the intake manifold.
There are also coolant connections into and out of the throttle body. Check those...perhaps with a small mirror and flashlight.
Good luck.
Good luck.
Jazz Cat (06-27-2013)
Good luck
Good luck
I had the coolant smell for more than a year, never a drop on the ground, and had to add about a 1/2 cup of coolant about every 2-3 months. When the frequency of adding became every 2-3 weeks, I decided it was time to investigate further. The (what I call) octopus of heater hoses back underneath and near the firewall were weeping at the connections. Had them replaced and have not smelled that sweet burning smell in about a year and a half. Undoubtedly, this is a common cause amongst our cars for the slight leak that is enough to trigger olfactory sensations.
Both TSBs plus other possible causes are in this thread: https://www.jaguarforums.com/forum/x...s-smell-50466/ . If you want to continue the gas smell discussion, we should move it to that thread to keep this one focussed on the coolant smell.
