old tensioners
Old 07-07-2019, 08:19 PM
cjdee's Avatar
Default old tensioners
I have 53k on a 97 XK8. I think it is time to replace the timing chain tensioners. What special tools do I need to compete the job?
Old 07-08-2019, 03:16 AM
bladerunner919's Avatar
Just the search button. I think this has been covered once or twice.
Old 07-08-2019, 01:24 PM
DavidYau's Avatar
Received 1,418 Likes on 755 Posts
Default Which tensioners are you referring to?
Cider,
Which chain tensioners are you referring to? Primary, secondary or both?
if it’s the secondary only, no special tools required using the zip tie method. Just take off cam covers and you’ll see the top tensioners. Easy job - just use a zip tie to secure the chain to the sprocket to keep timing as you change these tensioners.
For the primary chain tensioners, it’s a major front engine rebuild job. Stu46h has the most recent thread detailing the job with excellent photos. Very specific tools needed. See post #10 for the tools. Link below
https://www.jaguarforums.com/forum/x...ioners-214569/
Good luck. For me, this is top of the home car DIY achievement! Extremely satisfying when you ace these types of jobs
Old 07-08-2019, 02:07 PM
cjdee's Avatar
Originally Posted by DavidYau
Cider,
Thanks for the info. Not sure if I would do the primary tensioners myself or farm it out. I only have 53k on it now.
gtjoey
39
08-30-2016 06:02 PM
RobGardnerBlack
01-25-2016 12:31 AM
Daim
01-23-2015 04:36 PM
weisberg
01-01-2014 11:51 AM
Funkadelict Relict
03-31-2013 12:06 PM
Quick Reply: old tensioners
