One more supercharged XK8
Sooo, the engine is in its new home. Filled it up with oil/water, did some cranking with the fuel pump fuse removed and voila-it fired right up. First time it was idling rough but it turned out to be an air leak at the duct seals which is now rectified. Now it's purring like a kitten. The only 2 codes are for the VVT, as the ECU is expecting to have the VVT, but the supercharged engine doesn't have VVT. But this doesn't cause the restricted performance or any trouble lights, so I don't care.
But still some bad news. The guy who had rebuilt my supercharger messed everything up and now it's impossible to even turn it by hand. It can be seen in the photo that the rotors are hitting each other. So I am very "pleased" to be looking forward to take everything apart again to remove my poor old Heaton... If the guy manages to fix it soon, I'll put it back as a temporarily solution just to drive during last warm months. If not, than I'll be waiting for the Twin Screw kit which is paid for and being produced right now by Avos. Let it be POWER!
Yes, I also expect the tranny to be weak link, but so far it has been holding up well with Eaton. If it breaks after the Twin Screw installation, I'll rebuild it with stronger parts.
Ozzy_UK
45
02-19-2019 02:05 PM
Get_Jaggy_With_It
09-25-2015 03:09 PM
