One-Time No-Start--Why?
My '06 XK8 coupe has been running and driving perfectly, and starting right up, every time. Last night, however, I was about to head off to a meeting in the Jag and it would not start. All the instrument lighting was working and the computer's diagnostic procedure ran through as usual. Nothing happened with the starter, however, on repeated attempts. No click, no whir, nothing. No dimming of lights to suggest a bad battery (which is pretty new, by the way).
I switched to my Land Rover and headed to my meeting. This morning, I grabbed the Jag key and tried again. Started right up! Shut it off and tried again. Started just fine.
Now what? Any clue as to why it might have refused to cooperate last night? Perhaps it just didn't think a boring drive of a mile or two, to a meeting, was a suitable outing for such a sporty car.
Thanks,
Granville
Thanks,
Granville
Granville, I often have a similar problem. Turn key to start, nothing, starter does not engage. Dashboard lights are all normal.
No current draw (eliminates battery / connections), its like the theft prevention system doesn't recognize the key.
I turn key to off and try again. She starts right up! Once every 5 or 6 times I need to try it once more, a third time, but she always starts like nothing was wrong.
I've analyzed this for 3+ years now. Not sure what is doing it. I think back, did I move the key switch through on - run - to start extra fast?(maybe but who can say. I need to go out and test this intentionally now! I will post results); did I briefly step on brake? Is this a quirk related to a bit less than 100% charged?
I've just shrugged it off, heck it just takes a couple of seconds to cycle again - and she always starts. In retrospect, it has never happened with a fully charged battery!
Please do correct me if your no start was different, but when I saw your post it reminded me that I should try to correct this if I can.
Fyi, this is just as likely to occur on any of the 3 ignition keys.
Assuming this is the same issue as Granville has, Does anyone know which components are only energized after the car's successful interrogation of the security chip in the key?
Maybe we could monitor one of these components to validate the chip / key ring security is the culprit.
Thanks, John
Thanks, John
Thanks,
Granville
