Opinions Needed
Opinions Needed
so i stumbled upon this 98 XK8 with 154k miles, and which looks really good from what i can tell in the pictures, and says TLC needed, called the owner up, and he said its in Restricted Performance, and gave me a list of codes it reads
P1313, P1316, P0202,P1242
im a very hands on Person, so any work will not be a problem, my question is, is this a good/reasonable/smart choice, or should i just walk away from this, its located in Chicago, and i love 4 hours away in Michigan. The owner says he could drive it to Michigan (hes not actually going to drive to Michigan) with no problem. thanks in advance
1998 XK8 Jaguar Convertible
From: http://www.jagrepair.com/DTCforms/X1...C_OBDII_R1.pdf
The bank 1 vs bank 2 thing makes me wonder if the codes are correct or if there are typos.
If one or both cats are burned up from excess fuel that can get expensive or opportunistic if you get my drift.
$4k, not bad but could get better. If I could get it for a real fire sale I'd take a chance. Might be a few more surprises. See how bad he wants to unload it.
Mike
- Injector not firing on bank 2 -0202
- Sensor power supply circuit high voltage -1242
- Misfire rate catalyst damage bank 1 - 1313
- Misfire excess emissions - 1316
Mike
Gordo, im going down to Chicago anyway to look at 4-X308's, so i figured i would go and check this out as well, and the listing says $4k obo, Mike thanks for the info, is there anything sort of quick diagnostic i should do? to determine whether or not its a injector?
Charlene n John
09-28-2015 06:01 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
