Opinions on Rims for my black 1997 XK8
Old 01-30-2013, 08:49 PM
Marsden's Avatar
These are Coventry Hornets on this X350 XJ8. Always thought they looked muy caliente.
Attached Thumbnails Opinions on Rims for my black 1997 XK8-jagxj8pict0013-1.jpg
Premier1one (02-05-2013)
  #42
Old 01-31-2013, 07:10 PM
Premier1one's Avatar
Me Gusta mucho!
  #43
Old 10-24-2013, 05:08 AM
philhef's Avatar
Got these off eBay Look like the Arden wheels and cost about 500.00. They have many sizes and look awesome on.
  #44
Old 10-26-2013, 06:17 PM
I really like those.... Would you happen to have the link?
  #45
Old 10-26-2013, 11:01 PM
philhef's Avatar
Originally Posted by premier1one
i really like those.... Would you happen to have the link?
  #46
Old 10-26-2013, 11:06 PM
philhef's Avatar
Going to list my custom Dorchester grey impellers at some point. They look great on black car but since they basically match the trim on most of the XK8's, I'd think they'd look good on most colors!!
  #47
Old 07-11-2014, 10:13 PM
linkspider's Avatar
Maybe it is just me but I have seen loads of different rims for a 1997 Jag XK8 and I do not think you can beat an original chrome set it just looks right and its original.
Most of the rims out there on a Jag either look like a door to a washing machine or make the car look like it wants to bounce up and down in a rap video..
I ended up getting lucky and came across a set of mint chrome XK8 rims and tires for $250 the guy selling them believe it or not had managed to get a 22" rim on the back and I think a 20" rim on the front so he says it looked like ***** he was happy and so was I; what an idiot.
Stick with the original and forget dustbin lid rims.
  #48
Old 07-11-2014, 10:16 PM
linkspider's Avatar
Nice..
Originally Posted by philhef
Attachment 59702
  #49
Old 07-12-2014, 07:17 AM
Loxmth's Avatar
Factory 19" apollos are in my opinion the best looking wheel on an XK.
pitifulpluto (07-12-2014)
  #50
Old 07-12-2014, 07:34 AM
pitifulpluto's Avatar
I thought the apollos were were 18"?
  #51
Old 07-12-2014, 07:40 AM
Loxmth's Avatar
The ones on my 03 are 19" print out of options for my car confirms this.
Salu498 (10-04-2016)
  #52
Old 07-13-2014, 04:12 PM
mrgreenwich's Avatar
Will 2000 XK-8 rims fit on a 1997 XK-8?
  #53
Old 07-13-2014, 04:17 PM
XKRacer's Avatar
Straight swap right up to 2006 and later if you don't mind using adapters
  #54
Old 07-13-2014, 08:34 PM
rui's Avatar
rui
rui is offline
I've read somewhere that wobble nuts can be used for our jags.
if thats true, we can easily use PCD 5/120?
there are ALOT of options out there with this spec
  #55
Old 07-13-2014, 09:12 PM
grandell's Avatar
5x120 may fit even without wobble nuts, as the stud location is only 0.325mm different from where it would be with a true 5x120.65, and there should be a lot more clearance around the studs than that.
The most important thing is that you have the correct 73.9mm centrebore, as this is what actually locates and centres the wheel on the hub
  #56
Old 07-14-2014, 09:50 AM
blindside's Avatar
5x120 will definitely work perfectly, but since our wheels are hub-centric the center bore measurement is critical... when I bought my wheels (Avante Garde 310) I had to have the center bore "drilled out" by about 2mm to get it to the proper size (and the manufacturer said there was no problem in doing so). If the bore is too large then you just need to use hub rings that will take up the gap...
  #57
Old 07-14-2014, 03:31 PM
XxSlowpokexX's Avatar
Im in a sim situation. Everyone says I need black rims...EVEN the woman.....I kind of like mine as is...I was thinking of plasti dipping these just to see how it looks with a black rim as I can always peel it off
Attached Thumbnails Opinions on Rims for my black 1997 XK8-get-attachment.jpg
  #58
Old 07-14-2014, 05:41 PM
rothwell's Avatar
Received 1,264 Likes on 692 Posts
Originally Posted by xxslowpokexx
im in a sim situation. Everyone says i need black rims...even the woman.....i kind of like mine as is...i was thinking of plasti dipping these just to see how it looks with a black rim as i can always peel it off
Why go to all that trouble.
I took an assumption at matching the paint and darkening the lugs/centers to match.
Personally I think its way to much darkness. But I drive a "look at me officer" red one.
if you just hate the silver ...
  #59
Old 07-14-2014, 07:40 PM
rui's Avatar
rui
rui is offline
is that mat black plasti dip as well?
it looks awesome! been thinking about doing some as well
  #60
Old 07-15-2014, 05:39 AM
philhef's Avatar
I loved my black rims. Actually they were metallic black. Once I painted my car metallic black walnut, I changed but until I had the whole car re sprayed in the new color, the cheapest fix was painting the wheels.
Quick Reply: Opinions on Rims for my black 1997 XK8
