Orange Reflectors/Lights
there is no side repeater on mine; the front lens is just a marker light
Brian, I'm glad to hear he's enjoying my alma mater and doing well. I too was brainy my first year, the next two were a blur, then the last one I buckled down.
just to chime in and as the thread got me thinking what my car does - have 1999 XK8 convert. Went out and checked, my car does not have the small repeater lights, it has the green leaper logos with no lights. The amber oval lenses on the front fenders have lights wired to them if I feel in back, but neither one lights up either with headlights, parking lights or turn signals. Seems unlikely but I guess they could both be burned out.
The back red lenses light up with the headlights, seem to be just additional marker lights as no additional response with either brake or turn signal.
OK... here's what I'm thinking about doing: I'm going to have to repaint the whole left side because of the different color of paint underneath the bump molding. I'm thinking about taking out the reflector/light thingy at the same time, patching up the hole, and painting over it. That would give me the nice, clean look that I see in the pics that I've photoshopped. I'd have to do the one on the right fender, too, but since I'm already going to repaint the left side, doing the right front fender wouldn't really add much work. Thoughts?
#30
I took the liberty of taking off your door molding and filling in the reflector thingy. I removed the front turn signal's lens and replaced it with a clear lense. I also lowered it about 2 inches. I think I lowered it too much, but this was a five-minute photoshop. Don't fault me for bad paint job. Doesn't it look so much better now?
#31
My 98 XK8 has the green leapers and I thought it would be nice to have the clear lenses. Before ordering I took them off and found wired connectors putting out 10.27 volts when the lights are on. While 12 volts is required for full brightness I figured that the lower voltage would work but just not at full intensity. Well, I was wrong. The bulbs won't light at all. I checked the bulbs with a 12 volt source and they are fine and I checked the voltage at the connectors to make sure they were plugged in OK. All I can surmise is that the voltage output is at such a low amperage as to not light the bulbs. I'll look for other bulbs or maybe wire amber LEDs with a dropping resistor. Any ideas or recommendations here?
#32
#33
#34
LEDs would be the way to go. You might not even need a resistor to drop the voltage. Put a meter across the bulb when the light is on and see what the voltage is under load. There are lots of LEDs out there that work at various voltages. You can probably find some LEDs that work in the 3 to 12 volt range. Those would do the trick.
#35
Today I tried connecting an LED directly to the socket and all I got was a very dim glow. While 10 volts is present at the socket, apparently the amperage is extremely low. SO, I popped the front side markers and ran ran a pair of wires to the new lights from there and all is well. While I was in the area I upgraded the low beam halogens to the whiter (blue) bulbs. Looks nice! Now, as soon as the harness adapter arrives from the UK I can get on with my audio upgrade project. I guess it's nice to do some upgrades every 12 years or so.
#38
#39
Well, that's what makes horse racing. I agree that the orange lenses don't look so good but the clear looks nice on the Topaz and I think the smoked or clear would be nice on the silver. Driving in Houston where most folks seem to prefer large SUV's and trucks (my other car is a Jeep Commander) I'll take every advantage I can get at being noticed, particularly at night. I bought the pair from a dealer who offers both smoked and clear on ebay (grendleentertainment) for about $30 delivered from the UK. Took about week to arrive and amber bulbs were included.
#40
