Outside mirrors will not adjust
andyiiamm (02-01-2012)
Just a small point - the mirror folding in or out only occurs when you are travelling at under 10mph - ie, best when stationary. Are you trying to fold them whilst you are moving?
I don't know about automatic folding down. Mine don't, but I do it manually when I need to.
My mirrors started to act up last year, certain directions not working then finally the switch quit altogether. This last winter I finally took the door apart removed the switch and dismantle it. Do this very carefully and remember how each part is in it. The little contacts on the circuit board were corroded I had to sand them carefully (used 1200 grit paper. I covered them with dielectric grease and reassembled. Only one direction worked. I disassembled, re-sanded the contacts, re-greased and reassembled two more times and they it's been working fine ever since. I believe the folding mirrors were an option.
ebattreall (08-03-2012)
