Over Charging
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hope someone may be able to give me some advise, Removed the battery when I replaced the heater hose the battery was off for around 3 weeks when I now start the car up it reads gearbox fault and the dash lights brighten and dim,also the charge meter when slightly revved goes off the clock, I have checked all the connections and all seem to be fine I also left the battery disconnected overnight had the codes cleared but the problem is still there.
By charge meter, I assume you mean voltmeter. The truth is it is not really a voltmeter that will work properly if the battery is very weak, because it depends on proper operation of some of the computers in the car.
Sort of defeats the purpose, I know.![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Anyway, it sounds to me like your battery is close to dead. Either charge it or replace it.
Peter.snowdon (06-18-2017)
