over full level on dipstick
Received 2,190 Likes
I think I have the wrong dip stick in my 03 XKR. I think I accidentally swapped it with the one from my 01 XK8. It shows the oil level over the full mark. Does anyone know the correct part number for the stick as I want to order another one. I did a little research and came up with part number C2C22741. They want $25.99 for a replacement, sounds a little high.
Bill N
03 XKR
Bill N
03 XKR
Received 6,307 Likes
keestanis (04-16-2013)
No, I wouldn't consider that excessive oil use by any means. My 1999 AJV6 (134,000 miles) gets through about the same amount.
The primary concern regarding overfill is that it might cause the oil to foam when the throws of the crankshaft begin sloshing the extra oil in the pan. Aerated or foamed oil is difficult to pump, and in extreme cases could cause oil starvation.
There is also a secondary issue regarding additional parasitic engine drag created when crank throw must 'cut through' the raised volume of oil in the crankcase as it rotates. It is minor, but still a concern.
I run at the "silverstone" levels because it is factory sanctioned.
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
