p 0420 p0783 p1000 codes s type
The P0430 is pointing you to the O2 sensors or the Cat. The P0783 is a transmission code 3-4 or 4-3 gear load fault. The P1000 is a code that is a diagnostic monitor an item not to be concerned with at this time. Focus on the other two codes.
Link to codes http://www.jagrepair.com/DTCforms/X1...C_OBDII_R1.pdf
The Misleading Nature of the PO42O Code - Eastern Manufacturing
Found this interesting article made for a good read, I learned a little more about that code for future ref perhaps it will help, or not
Jeremy
Jeremy
