P0010?? Resolved
Received 4,317 Likes
P0010?? Resolved
heading home from work this afternoon - sitting at a stop light, I received a Restricted Performance with CEL - RP cleared when I started moving again (less than 10 seconds after coming on) but CEL still on.
Checked codes - have the 171/174 bank 1/2 lean but also have a P0010. Torque listed it as a Cam Position sensor bank 1 - DTC chart lists as VVT ckt malfunction bank A
Car ran fine rest of way home - any ideas - should I drive to indie in the am or have towed?
JagV8 - yeah been chasing the lean codes off/on with the help of the other threads - really need to do a smoke test.
Jon - just replaced the vvt seals this past spring but I think JagV8 may be on the right track with the connector. When I disconnected the cable to the vvt solenoid, the plastic between the 2 terminals is cracked/damaged - so will look at replacing the connector to see if that clears the issue.
I drove it yesterday for a bit with no issues but will drive the XE the next few days until connectors arrive
Orthodixie (12-13-2017)
