P0121
Hi Folks. I do not intend this info to be an easy one size answer for this code re the trottle body/throttle pedal but I thought I'd pass on what appears to have been a solution for mine, 2000 XK8.
I'd get it occassionally and I tinkered with the linkage then with cleaning the contacts in the plugs and it would be fine for a while then pop up again, usually after a good run then repeated movements in traffic. It occurred to me that the spring assembly was not always returning correctly. Why, I couldn't see but finally I sprayed lubricating oil liberally on the pedal cable and around the spring. I worked it in manually and I haven't had a code in a month now. I also returned the cable to a very tight condition rather than a bit loose by watching to ensure that fully off still rapped the butterfly back against the stops.
Hope that helps someone.
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Exact same problem as You. Only at very slow speed and very intermitten(maybe every 100 miles or so) Same code p0121. TB was cleaned last year and I don't have mismatched plugs. Thinking about sending TB in for rebuild. Let us know if the lubrication was the solution. I have a feeling it's gonna come back, but I hope not! Good Luck.......mick99
Hi all:
Had this code and cleaned and made sure tb connectors were tight. No joy on that as it returned. A fellow member suggested cleaning the ecm connectors and check a ground strap under the ecm unit that was sure enough loose. Once I cleaned and tightened it has never returned. This was last year. Also if you have a battery tender it may be a good idea to charge up your battery as its been mentioned that a weak battery can cause these issues. My car is a 99 xk8 convert and a left hand drive. The ecm and ground strap are under the hood by the windshield on the passenger side under the black lid. And my ground strap i could easily turn it by hand. Been almost a year now and its never came back ( famous last words !!!! )
Howard
Howard
Rip Reed (07-20-2012)
