P0121, cruise control unavailable, rough running
This started yesterday: had been in the car for about 40 minutes idling at night when suddenly I got the following faults: Engine System Failure, Cruise Control Unavailable, and both amber and red warning lights as well as a CEL. I also noticed rough running and rising revs. I turned off the car, waited a couple minutes and the faults cleared.
The symptoms returned this morning when I was in the parking lot of the university. This time I was able to use the code reader and got P0121. I think this may possibly be the TPS? I can’t seem to find the part number for the throttle position sensor.
Right Path
I think you are on the right path. Had the same problem with my 2000 XK8 and it was the TPS. On my car the part number was right on the part. It is a Denso part and is also used by Toyota on their TBs. As you car is a 2004 XKR I believe your TPS is different than mine. Good Luck.
Ok, I will check my TPS when I clock out of work. I hope mine also cross-references with a Toyota.
It takes a special tool
Thanks! I was able to source an identical one on autozone cross-referenced to a ‘96 Camry. However I am having trouble removing the original one. My T-15 bit is not going in. Not even the tamper proof one. T-10 is too small and T-20 is too big. The bolts do look corroded. I will attempt to wire-brush them before I go nuclear and just remove the TB.
giandanielxk8 (10-28-2022)
Security Torx
kstevusa (10-29-2022)
I have learned that these sensors, even if they look the same, the internals are different. I tried one from Autozone, one from Toyota Camry, a one from Geo Prizm, and none worked.
There’s one from a Mazda Protege made by Denso, but the last 3 digits of the part number differ. At this point I am hesitant to try it out.
Does anyone know of a reliable reseller
Check This out
I have learned that these sensors, even if they look the same? The internals are different. I tried one from Autozone, one from Toyota Camry, a one from Geo Prizm, and none worked.
I ended up purchasing that one even though it's all the way in china. At that price I don't mind throwing away that money.
David Dougherty (10-30-2022)
