P0121 TPS issues RESOLVED
Old 03-18-2015, 08:04 AM
K.Westra's Avatar
I'm getting this error again and occasionally a P0222 with it. I'm going to pull the intake elbow, remove the wires and solder them together. I'm going to order the Toyota part and put my gold contacts into it. This will ensure I have as good of a connection as it is going to get. It's ironic. I drove the car for a week after pulling it from storage and then took a 500 mile trip for our anniversary with no issues, then get home and now I'm getting pretty persistent issues.
  #42
Old 05-26-2015, 11:42 AM
K.Westra's Avatar
I installed the Toyota part (didn't put my gold contacts in since I feared I would damage the new Toyota part getting the old contacts out), soldered the connections...and got zero improvement.
Finally, I ordered a rebuild TPS off eBay from AutoECU. After installing that, I have not had an issue since, so hopefully my problem is solved. A couple of notes. I am not sure if the TPS is held on with an elusive T17 torx (try to find one, it isn't easy) or as some have said, a double cut Robertson S2 (that seemed to fit, but mine stripped when I tried to turn and wouldn't go), but I ended up using a cutoff wheel on my dremel and carving a notch for a flat head screwdriver.
Hopefully this helps others chasing these codes (P0121 with an occasional P0222) as it seems to have finally cured mine. Now I can focus on the P0175 with Restricted Performance (thinking O2 sensors, but want to check fuel trims)
Before
After
  #43
Old 05-26-2015, 04:32 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
You can get the bolts at your local Lowes store
  #44
Old 05-26-2015, 04:34 PM
Gus's Avatar
Gus
Gus is offline
Remember that the P0121 is related to the plug/wiring to the throttle body.
  #45
Old 05-26-2015, 04:43 PM
K.Westra's Avatar
I've done just about everything imaginable to the plug side of things with limited success, but this seems to have finally cured it. I guess time will tell.
  #46
Old 05-26-2015, 04:45 PM
K.Westra's Avatar
Are the originals Robertsons as some have speculated? I couldn't tell, even with them in my hand. They hold tight and are eady enough to get in/out as is now, so I will leave them as is. If i had done it when the local stores were open, I probably would have replaced them, but I just wanted it done. 150 miles later and no errors, so I think it is licked finally.
The following 2 users liked this post by K.Westra:
Gus (05-26-2015), RJ237 (05-26-2015)
  #47
Old 05-26-2015, 07:24 PM
batroute's Avatar
Anytime Tools 11 pc 5-POINT STAR TORX TAMPER PROOF SECURITY BIT SOCKET SET - Pentagon Socket - Amazon.com Anytime Tools 11 pc 5-POINT STAR TORX TAMPER PROOF SECURITY BIT SOCKET SET - Pentagon Socket - Amazon.com
Those are the tools for the fasteners - 5 point tamper proof Torx- sometimes called pentagon stars. I bought mine off ebay for less than $10.
  #48
Old 05-26-2015, 08:21 PM
K.Westra's Avatar
Except the screws aren't tamper-proof (no center pin) and the T17 isn't part of this set, so no luck there. T17 is pretty rare and I saw on a different forum that a Robertson square S2 should fit. I believe it does...but mine were stripped enough to not work.
  #49
Old 05-26-2015, 08:26 PM
Gus's Avatar
Gus
Gus is offline
The ones at Lowes was fitted for an Allen wrench and it seemed to be easy to work with all the other stuff in the way. I know because i replaced both of them.
  #50
Old 05-26-2015, 08:28 PM
K.Westra's Avatar
We're your originals hex head? It seems like a good idea to go that route with a replacement, I just reused my modified originals
  #51
Old 05-27-2015, 07:37 AM
batroute's Avatar
It doesn't matter that there isn't a centre pin - they still fit screws. Included in the set I bought is one marked S2 T20 and that's the one I used. Worked perfectly and didn't damage the fastener. I 've just double checked on a spare throttle body I keep.
  #52
Old 05-27-2015, 08:31 AM
K.Westra's Avatar
Interesting. My T20 didn't fit, (and is why I was thinking it was an elusive T17, which a search happened to bring me to an X-Type owner with throttle body issues and to a cargo trailer site, they also apparently are used to adjust some GM headlights) that could be because it was partially stripped. I wonder if it was messed with at some point along the way.
  #53
Old 05-27-2015, 08:53 AM
batroute's Avatar
As far as I can see the S2 T20 fits perfectly but I don't have a T17 to try- it certainly works without chewing up the fastener - I've had another look before coming back to the computer. Those 5 point stars are also used on Mercedes - I know because I have an ML in the U.K.. I am told by others those fasteners are on other European cars also.
  #54
Old 05-27-2015, 09:13 AM
aode06's Avatar
I agree with you, I found a TPS that did not require soldering, but the face of the TPS was clocked differently than the JAGS, therefore requiring you to swap faces.
That does not look easy in my opinion ,so I told others to have their old units rebuilt instead by a reputable automotive computer rebuilding company.
  #55
Old 05-27-2015, 10:34 AM
K.Westra's Avatar
Must just be my messed up fasteners then. I wonder why it was messed with in the past? I didn't get the impression the previous owner would mess with those sorts of things, but you never know. Plus you never know what some of the service shops could have done.
It's interesting how many posts we've accumulated about those little fasteners. I'm just happy the replacement TPS seems to have finally cured it
  #56
Old 05-27-2015, 10:35 AM
K.Westra's Avatar
Exactly, when I looked into it, I didn't want to risk not getting it quite right, when it isn't a huge investment to go the rebuilt route (and get the warranty to boot).
  #57
Old 08-21-2015, 07:49 AM
Glenn Barickman's Avatar
This information may be out there, but I replaced my electrical leads with the "gold" kit for my throttle body a few years ago and notice that the connector was not in the greatest shape. It started giving my trouble some time back and the shop I took it to used a Toyota connector part #90980 10711 rather than the $1200 wiring harness from Jaguar. Thanks to John of Autobahn of Illinois I googled that part number and it looks the same. Just wanted to share this info
RJ237 (08-21-2015)
99xk8guy
05-28-2024 09:36 PM
JarodL
03-07-2024 01:39 AM
Forcedair1
05-14-2023 03:28 PM
TXJagR
06-20-2016 01:02 PM
aarahim
09-07-2015 03:12 AM
Quick Reply: P0121 TPS issues RESOLVED
