P0171 & Restricted Performance (Solved)
Check your gas cap
I have an '03 XK8 NA... had those codes when I purchased it. I found (THANKS TO THIS FORUM) a rotted air intake hose, which I repared... all was well for 6 months.
Now its back... Right after my last fuel fill-up? Sounds like oxygenated fuel to me.
Any chance this may come from low bat voltages??? mine does it at start-up.
I'm wondering why its monitoring long term fule trims at start-up?
Thanks Gus!... I was wondering about that. I am careful on replacing it... can I check it for proper venting or sealing? I did also notice the windows lost thier memory and, I also saw the DSC fault at start-up... I thought these were posible signs of low batt voltage. The car starts, idles, and runs well otherwise... I'm due for a fuel filter change soon anyway... I'll see if that helps.
I was checking-out your web site today... IT"S GREAT! THANKS for all the great info!!!... VERY WELL DONE!
The loss of the window memory is an indication of a low battery but the best way to check it is to AutoZone, Sears or PepBoys and have them check it out with the equipment they have.
The P0171 is a lean indication and most of the time you will find that you have a leak (crack) in the pipe from the air filter to the throttle body. I would check it first and see what you come up with. You can use this link to help in finding your problem http://www.jagrepair.com/images/Auto...otos/P0171.pdf I hope this helps.
Also Thank You for your kind words about my web page.
UPDATE: the codes came back. As Gus and others have indicated, it was a leak in the breather tube from the crankshaft. I went ahead and got the new IMT valve o-rings as well. On my 02 X-type 2.5, it was a really quick repair. The o-rings were $4 each and the breather hose was about $12 all from the dealer. It's been a couple of weeks with no new lean mixture codes. If in doubt, just replace the hose and o-rings. It's too cheap not to.
Thanks Beav, I FORGOT PROPANE... always grabed for the can of brake-clean. I'll be trying the propane method after the Holidays. I repaired the intake hose last spring.... was good all summer, may have developed a leak in the intake hose or the o rings on the norma fittings. Funny though... she does't RUN like it has any leaks at all.
1999, 96, 97, chrysler, convertible, inop, jaguar, jaguard, p0171, performance, restricted, sebring, speedometer, xj8, xk8
