P0300 & P1316 - Restricted Performance - Clearing Codes
Old 03-28-2012, 06:02 PM
K.Westra's Avatar
Default P0300 & P1316 - Restricted Performance - Clearing Codes
Last summer I would occasionally get a Restricted Performance to pop up. It was always on a warm day, and always after the car sat for about ½ hour and then was started and taken for a short trip. The Restricted Performance would clear itself in a minute or so, and it would clear whatever codes caused it before I could check them.
I thought the problem had corrected itself, but today it popped up today. I managed to pull into the driveway and run inside to grab my code scanner. The Restricted Performance had cleared before I could scan, but the codes hadn't cleared yet this time.
I got a P0300 along with a P1316. I checked the JTIS and this forum and came across this: https://www.jaguarforums.com/forum/x...misfire-49099/
The car only ran rough once last year, but the symptoms are similar.
The car is due for a fuel filter replacement, so I will do that, and probably run through some BG-44K for good measure. Any other initial steps I should look into, or just do those and see what happens from there?
Old 03-28-2012, 06:46 PM
GGG is offline
Received 16,851 Likes on 12,186 Posts
Fuel vapour lock in the lines used to be a problem years ago on hot days which would result in loss of power and/or misfire. It would clear as cool fuel was drawn though from the tank.
Symptoms sound the same but it could just as easily be related to the 10% ethanol fuel you have in the US. We currently have 5% and there's far less reported instances of filter and pump problems.
dude1579 (07-28-2018)
Old 05-02-2012, 07:54 PM
H20boy's Avatar
Received 1,150 Likes on 753 Posts
Keith, did you ever resolve your CEL code? (tsk, tsk)
Old 05-03-2012, 10:03 AM
K.Westra's Avatar
I'm not sure. I haven't got it to show up again, but it's been so intermittent, I'm not sure if it's completely gone. I ran some BG-44 though the system, but I haven't done the fuel filter yet.
Old 05-03-2012, 07:44 PM
K.Westra's Avatar
You cursed me, Matt I got a Restricted Performance, briefly, for the first time in a while. I guess I will be doing the fuel filter next.
D.K
12-10-2023 02:05 AM
Shawn Svacha
02-06-2022 04:53 PM
ccfulton
09-20-2015 05:15 PM
mrplow58
09-09-2015 11:27 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: P0300 & P1316 - Restricted Performance - Clearing Codes
