P0308 trouble code - Resolved
What a great forum. I have a 2001 XK8 with a P0308 trouble code which indicates cylinder 8 misfire detected. Car has 113,000 miles and I purchased the car with 80,000 miles.
As I see it a good move would be to replace the one coil for cylinder 8, change all the plugs (I have not done it and guessing it was not done before).
Any suggestions or advice would be appreciated.
Cheers from Minnesota
2001 XK8 (not super charged)
113,000 miles.
113,000 miles.
Also, if any of your spark plug wells are filled with oil, you have a cam cover seal leak, which can also cause a misfire.
It would be very wise off you to look into your tensioners via the mechanic that services Jaguar cars.
This is very serious potential break down with your cars mileage.
I would almost be surprised to find they have not been changed over with that many miles and know noted break downs.
trust me you will not be a "new guy" for long, if you do not get the chains and tensioners changed out.
They are internal parts to the engine and critical.
Happy Motoring...
thanks everyone for your help. Cyliner #8 had a significant amount of oil which was the cause for the p0308 trouble code and the reduced engine performance light. New plugs and new casket. I had them cleaned and rerarrange the boots for the coils which has solved the problem and the car runs like it should.
I put the car away for the winter and only put on 5000 miles per year on the car. Next spring I will have someone look at the secondary tensioners and hopefully smooth sailing for awhile.
Cheers y'all
Cheers y'all
Received 6,307 Likes
Poet
10-06-2015 09:40 PM
