P0327 Knock Sensor right side out of range
Had the radiator hose blow off the thermostat housing and since have the P0327 code and restricted performance. Cleaned everything up and put it all back together but still have the P0327 and RP. Guess that the KS is dead at the moment. Any experience with resurrecting a KS or just replace it?
https://www.jaguarforums.com/forum/x...-weird-120417/
Testpoint
Check this out, it might be something you can try.
Wayne
Testpoint
Wayne
I cleaned the connector with WD40 at the thermostat tower and reset the code. It went away for a couple miles but came back. Did it again and will try tomorrow. I can forgive it for failing under its antifreeze bath but should clear up after any electrical issues are resolved. It would seem reasonable that the internal sensing elements should be at least a little water proof.
The sensor seems relatively easy to remove/replace and will try that before installing a new one.
Testpoint, I used a small wire brush, shaped like a paint brush to clean the knock sensor on the bottom after taking it off and holding it with a pair of needle nose and the same brush to get the ground cleaned off with out any undue stress. Just don't drop the nut. A three prong pick up after it's loose will do nicely.
Wayne
Wayne
Tom, I had the same issue with the knock sensors what I found out is that water/moisture of any type around the knock sensor is not good. I can tell you that I replaced mine without removing the manifold just be sure to use an adhesive to hold the nut in the socket and when you unplug the sensor tie a string around the lead to help you pull the new one in. I did mine in the parking lot of my condo and did not take photos. Sorry!
aholbro1
08-05-2021 05:02 AM
Aus V8S
11-13-2015 11:01 AM
KarimPA
09-12-2015 08:15 AM
joesoap
09-10-2015 01:09 AM
