"P0335" Crank Position Sensor. How to Change?
Old 09-13-2010, 01:01 PM
hm1's Avatar
hm1
hm1 is offline
Default "P0335" Crank Position Sensor. How to Change?
I'm getting intermittent no starts, and sometimes the car stalls. I hooked up the OBD2 Tester and I'm getting "P0335". Does anyone know how hard it is to change? Or where it it?
Old 09-13-2010, 01:18 PM
itspec60's Avatar
The CPS is under the car on the bell housing. If you get under the car you'll see it at the bottom of the housing. It's easy to take out...one bolt. Try cleaning and checking the electrical connections.
Old 09-13-2010, 01:30 PM
hm1's Avatar
hm1
hm1 is offline
Do you think its better to clean it or just buy a new one(its under $100 with new wiring and connectors)??
Old 09-13-2010, 01:58 PM
itspec60's Avatar
I'd crawl under and take a look before I'd buy anything. But, thats me. You may just have a corroded connection or a bad wire.
Old 09-14-2012, 10:38 AM
konshu's Avatar
I know this post was awhile a go but did replacing the ckp fix the prob?
Old 09-14-2012, 10:44 AM
steveinfrance's Avatar
Konshu,
If you don't get a reply try sending a PM to HM1
konshu (09-14-2012)
dsnyder586
04-04-2019 02:38 PM
afterburner1
12-16-2015 12:12 AM
Bones
09-08-2015 08:34 PM
gregster41
General Tech Help
09-04-2015 03:51 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: "P0335" Crank Position Sensor. How to Change?
