P0354: A little mystery...
Way back in 2011 I had a problem with my A4 coil throwing P0354 (Circuit fault) and P0304 (Misfire) codes. I replaced it and all was well.
Well, the problem has returned; but that's not much of a story...
At the moment the code only trips when it is exceedingly damp outside. We've had a string of warm winter days that creates a good deal of fog and generally damp conditions. That's when the problem manifests itself. When the weather clears up, so does the problem.
Oddly, too, is that it is always the same coil - A4 - causing the problem. I've checked the relevant wiring and connections, etc. for faults and never find anything. Maybe it is the cheap coils I'm buying!
I just noticed another odd thing. If you do a Forum search on P0354 you'll get 6 or so threads. In each of those threads, everyone has the same coil going bad - A4. What's with that?
That being cleared up, what, as an example, is P0354 telling me and why must it always precede P0304?
Each code in the series from P0300 (random misfire), to P0304 (misfire cylinder #4), and P0354 is for a primary or secondary ignition coil malfunction on cylinder #4. Each progression in the code sequence indicates a slightly different and decidedly more difficult and possibly more expensive problem to properly diagnose. From the basic random misfire to the more specific coil and or cylinder, etc.
All the module can really detect is that there's probability of such a problem not a certainty. You might also get some emissions codes as well if the misfire is severe enough or goes on for awhile.
Spurlee (12-27-2014)
