P1242 Sensor Power Supply high - what does it mean ?
Here is the P1242 'possible causes' from JTIS.
TPS - Throttle Position Sensor
PPS - Pedal Position Sensor
FTP - Fuel Tank Pressure
Since the first two involve replacing the Throttle Body I would suggest that you start with the FTP sensor which is associated with the evaporative control system.
You need a copy of JTIS: https://www.jaguarforums.com/forum/j...how-use-52643/
Do you know if the TB has been replaced by Jaguars service action S514? It appears that the TB had a problem with that MY this link might help Xclusively Jaguar - Facts and Information - For all your Jaguar needs.... Jaguar Cars, Used Cars, Classic Cars, Jaguar, Daimler, Cars For Sale, Parts, Automobilia, Accessories, Buyer's Tips, Newsletters, Information, SS & Pre-war, 1950's Sports, 1960 As for the codes I am attaching a DTC code Summaries http://www.gusglikas.com/images/Auto...%201997-99.pdf You could remove and clean the connectors to the TB first and see if that helps before replacement. As a note you can purchase a rebuilt unit that will work just fine. I hope this helps!
kr1957 (04-09-2013)
Here a short status report:
To test point: I cleaned all connectors around the TPS and the FTP on top of fuel tank. I also checked wiring and vacuum hoses. The hose who fits to the black round canister on top of the throttle boddy had a very loose fit. Thanks for the JTIS info.
To GUS : I cleaned connectors. Thanks for the other info. I do not know if car went under a PIP. But since SN is very young , he may only got an soft ware update.
I fueled the tank to 100% , and with all the cleaning , up to now no problem. Will try to repeat the problem from full tank to low tank. Will report back later.
Thanks you all , very good forum here in US.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
