Painted Calipers
Red Calipers Look Great
I think the red painted calipers look great. I used the duplicolor brush on kit with mine. I replaced the pads and rotors at the time and got some really cool slotted rotors. I have aftermarket GfG 3 piece wheels and had the centers rechromed and the outers powdercoated in black.
Red Calipers with Clear Coating
Here are a couple more pics showing the whole car and a side angle profille. It was a little rainy last night so those specks on the car are rain drops.
After I painted the calipers I tried to use Dupli-Color Engine Enamel with Ceramic clear coat but when I sprayed it on, the red paint would begin to melt off. I think it's because I used it over an hour after the paint had dried. Maybe if the red was still tacky, the clear coat would stick and not interact with the duplicolor red. I even tried waiting a week after the red had fully dried and cured, but when I would spray on the clear coat, it would still tend to melt off the undercoat.
Btw, the vinyl letters are made to withstand high temperatures so clear coating may not even be necessary. Let me know if any of you guys know what's happening with the paint interactions. I've heard of a lot of guys using clear coat and haven't heard about this problem.
#28
JonWat and dirtyodwyer,
I used Rustoleum Crystal Clear Enamel and did not have any paint interaction or running. What was the temperature outside when you applied the clear coat? Most clears are very, very sensitive to temperature and should only be applied in temperatures probably above 70 degrees, otherwise they dry very cloudy looking. As you can see below, there was no problem with mine.
#30
#31
#32
Gold leaf is 23-24k gold pages, which you can apply to the caliper to achieve a real gold finish, then you just clear coat it over. Don't know if it works, but I think it should be wicked
#34
#35
If your calipers get warmer than 1064 degrees, it could be a problem. Most paint should have evaporated by then, anyway. If you manage to heat your calipers that much, I believe you should consider adapting your driving style.
#36
#37
#38
Open to suggestions while we are all on this topic.
#39
Not classy enough is my opinion for my colour (metallic gold!), on blue however it could look really nice, just the same as it would on red or black cars, but gold is a funny one to match up, either painted calipers will look great, or really clash and look awfull.
Still as I say, everyone has a differant opinion on colours depending on taste...
#40
