parking sensor removal procedure
Assuming you have the Jaguar version and not aftermarket.
Howdy Folks: EDIT 8/31/3013 see post #9 in that you may also have a plastic panel/strengthener that may require some cutting for access.
Just a little extra info for what is is worth. I was able to pickup a used right angle connector outer sensor on Ebay for $25. Even though it was the right angle connector for the outer sensor locations, I was able to manipulate it for the inner right sensor installation without removing the bumper or such. Afterwhich, I conclude that straight and right angle sensors are interchangable. If one has physical limitations such as larger hands than mine, then a different method may need to be used.
The paint I used was Dupli-Color BGM0347 Med Gray Met. from Pep Boys which I could not tell from the original Quartz Met. (I do not claim that it is a match for say a fender repair)
Last edited by Dr. D; 08-31-2013 at 09:03 PM. Reason: Possible additional cutting required
worrasf (08-31-2013)
I was thinking the wireless version so I don't have to run a wire from the bumper into the car, I was looking at this from Maplin but for a 'Wireless' kit it seems to have a lot of wire... Anyone used it?
Any advice gratefully received, and I promise not to paint it yellow
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Hi, I was thinking of one of these for my 1999 XKR, does anyone have any advice/recommendation?
Any advice gratefully received, and I promise not to paint it yellow![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
The wireless part is the receiver (usually in the rear bumper) to the interior warning unit. You still have to run wires to reverse lights for rear sensors and brake lights for front sensors.
I'm still looking into these also.
Howdy Folks:
![Icon Twocents](https://www.jaguarforums.com/forum/images/smilies/icon_twocents.gif)
They are a tad fiddly to remove but the previous post with parts diagram was very helpful and once I'd figured the maneuver it only took a minute or so - but they are tight.
The connector is a straight swap so plugged new unit in before install - ignition on - reverse gear -warning alarm gone (actually made intermittent beep probably because 1 sensor was dangling down) and all 4 sensors "ticking"
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
![Icon Emm](https://www.jaguarforums.com/forum/images/smilies/icon_emm.gif)
The right angled connector fouls a plastic panel inside the bumper (hence the straight one as standard) and would not go through the hole! The solution was to trim away a channel in the plastic with my handy dandy modeling drill. It needed approaching from both behind the bumper and via the sensor hole. The wiring harness also needs freeing from it's cable ties to give more free play. Anyway, after removing about a 3 x3 inch bit of plastic (totally hidden from view) the right-angled sensor fitted a treat
Ignition on - reverse gear - no alarm! Silent. I assume the unit has now reset itself as all 4 sensors are ticking. I've not tried it out in anger by reversing as it started to rain just after finishing the job but I'm pretty hopeful all is well.
Reckon i've saved myself mucho denaro thanks to Jaguar Forum members posts.
Steve
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Wiring harness tidied up and secured with new cable ties.
Steve
Steve
I did not do any whittling on mine, but I do remember it as being a puzzle in close quarter manipulation. It seems like I used a spark plug socket on the tip of my finger at one time and maybe I plugged the connector in AFTER I put the sensor all the way thru the access hole. Sorry that I did not document it better when my memory was fresh. At any rate, I would be interested in seeing a photo of the materials that you whittled. Mine is still working fine. If I need another sometime, I would be glad to pay you 4X what you paid.
Howdy Steve:
I did not do any whittling on mine, but I do remember it as being a puzzle in close quarter manipulation. It seems like I used a spark plug socket on the tip of my finger at one time and maybe I plugged the connector in AFTER I put the sensor all the way thru the access hole. Sorry that I did not document it better when my memory was fresh. At any rate, I would be interested in seeing a photo of the materials that you whittled. Mine is still working fine. If I need another sometime, I would be glad to pay you 4X what you paid.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Steve
I wonder if the one you replaced was the other centre sensor? On my car the off side centre sensor has a gap in the plastic bumper strengthener that isn't present on the other side - weird and if it was this sensor that had gone on mine then the right angled one would have fit without needing to remove any plastic - I guess there are many variants.
Steve
Steve
Yep - if your bumper is the same as mine there will be a gap in the plastic strengthener next to the sensor hole on the RH centre one but not on the LH
Thanks for pointing this out.
Seeing that yours is also a 2002 XKR, there is a good chance that you won't, but you will need to determine if you have access holes (although not easy access) for the inner sensors. I did mine almost 4 years ago and still have had no problems since including the right angle sensor that I put on the right inner.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
