Parrot i9200 in 2001 XK8?
Not sure if this is much help but I've had a Parrot i9000 installed into a 1999 XK8 and I assume the basics are much the same. I had to get a specialist installer to do it so don't know the technical requirements, but can at least confirm it's possible.
I use it with my iPhone and have a Brodit cradle which the charging lead connects to and I can just drop the phone into. The Parrot remote unit controls the volume, track changing etc and it automatically mutes/pauses the music when you get a call.
The remote mike for the handsfree was installed by the top of the rear view mirror and it all works through the factory stereo, without having to switch the stereo on, so the aerial stays down. Volume etc is only controlled by the Parrot remote and not the dial on the stereo or steering wheel controls.
All in all it's quite a neat unit/install and seems to work pretty well.
I would imagine if you're reasonably competent in this area that you could fit it yourself and save an expensive specalist install, but if I recall you do need some kind of additional adaptor for it to work with the Jag stereo.
I'd have kept it. I have one installed in mine. It was professionally installed and I had the display put near the door, rather than the centre of the dash, so it's till visible but doesn't spoil the look of the dash. I have the contols on the steering column above the ignition.
One mod I did was rather than run the system from the Parrot's own amp was to take the line out and splice it into the CD input for much better sound quality. (They should have ffered that facility as standard).
Works fantastic. Heartily recommended. Why did you return it?
Here is a writeup on the Parrot MKi9100/9200 installation:
https://www.jaguarforums.com/forum/x...e4/#post430953
I hope to start by running a rear view camera through the Nav screen activated when in reverse gear. I understand that I will need a suitable camera and one of these https://www.carconverters.com.au/pro...erter/233.html. The next project would be to install A Parrot MKi9100/9200 for the phone. To use the existing buttons on the steering wheel, I am told I need a UNIKA. From what you say, these projects won't interfere with each other.
As two discrete projects, you should be fine.
I would probably look at:
JAGUAR XK/XKR 2002-2006 NAVTOOL VIDEO INTERFACES
On mine I removed the rear seat, ran the video cable under the seat and along the side of the transmission tunnel up to the dashboard. All pretty straightforward.
Here is a photo of the CD changer/pump showing the hydraulic hoses running off to the left. (To get the reverse lamp feed I connected a wire up to the light cluster on the right.)
![](http://dibbit.com/wp-content/uploads/2018/04/cd-changer-rear-light-640x480.jpg)
englishmaninla (04-24-2018)
